This does not continue for just a few stitches but carries on until I raise the foot, or switch off the machine. I'm only sewing cotton fabrics. I've checked the foot pedal in case something was causing it to stick, but can find nothing.
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
SOURCE: How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
SOURCE: Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
is sounds like their could be a short in the machine or the
computer main board could be going out. I suggest having the
machine check by a sewing machine technican
