Https://www.manualslib.com/
Try this site
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
SOURCE: I am trying to fix my xantrex freedom 10
In google type what model it is then after that type internal wiring diagram.
my 458 will not allow 110 volt power in my boat..the 12 volt circets work fine ..is there a switch in the 458 that might be stuck??
SOURCE: Is there a bench test for the Xantrex freedom 458
My experience has been thay there is no real "bench test" available to the general public. You can do some testing if you are familiar with how to read the color codes on resistors, and know how to test relays. There are two fuses inside, so you can check their continuity. Before going to this trouble though, get on line and download the Xantrex trouble shooting guide, bulletin No. 512-0084001-01 rev1. If that is ok, it'll be a trip to the dealer, where you'll learn that it costs about $400 to replace the board. I'm on my second one, in two years, so they aren't a long life article I'm afraid.Hope this is helpful for you.
