20 Most Recent Xantrex Technology DR3624 Inverter/Charger Questions & Answers
WHERE CAN I GET A CONTROL BOARD FOR MY XANTREX DR3624
Do you still have the command board?
3/1/2019 1:05:59 AM • Xantrex... • Answered on Mar 01, 2019
Xantrex Trace DR2424E, looking for service manual and schematics
LOOKING FOR A REPAIRER FOR MY XANTREX IN THE UK
7/20/2014 3:37:50 PM • Xantrex... • Answered on Jul 20, 2014
How can I access battery equalizer on the Xantrac DR 3624 inverter when I lost the button on the panel?
Is the switch still there? If the switch is still there you might be able to activate it with a pencil eraser or something like that.. If you have lost the switch then you will not be able to equalizer your batteries
6/20/2014 12:46:37 AM • Xantrex... • Answered on Jun 20, 2014
0answers
POWER STAR LW
Be the first to answer 8/18/2013 3:31:53 AM • Xantrex... • Posted on Aug 18, 2013Be the first to answer
Why won't my water pump shut off or run properly when my generator is charging my batteries through my dr3624 series inverter/charger
This sounds very strange. Send me an e-mail with more details at va7rv AT hotmail.com
4/8/2012 10:07:44 PM • Xantrex... • Answered on Apr 08, 2012
I need a control board.
You could buy the control board from :-
http://cgi.ebay.com/Xantrex-Inverter-Repair-Board-DR3624-Control-Board-/260652658387?pt=LH_DefaultDomain_0
I hope i have been helpful.
Thank you!!
11/6/2011 9:48:11 PM • Xantrex... • Answered on Nov 06, 2011
0answers
Why does my dr3624 only put out 98 vac, its rated
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
3/30/2011 5:04:51 PM • Xantrex... • Answered on Mar 30, 2011
0answers
I have just inherited a used dr1524
2/22/2011 5:57:19 AM • Xantrex... • Answered on Feb 22, 2011
0answers
0answers
2answers
I have a Xantrex DR1512
Inverter do not charge for a couple/few reasons, one, the battery it's trying to charge has a too high internal resistance, and the sensing part of the inverter, is unable to properly detect, and charge the battery. The second is where the actual charging circuitry itself, has a failed component or the like, in the output/input control circuitry, that must be fixed, and thirdly, the CPU, controller, has faulted, or the sensors feeding it have failed. To have any chance of a repair one simply must obtain a thing called a service manual, this will give you troubleshooting steps as well as a circuit diagram too. However these units are very sophisticated, and home repair isn't really recommended. Also remembering you are indeed dealing with lethal voltages so all safety precautions must be undertaken.
Operations manual below.
http://powertool.manualsonline.com/manuals/mfg/xantrex_technology/dr1512_dr2412_dr1524_dr2424_dr3624_dr1512w_dr1524w_dr1512e_dr1524e_dr1548e_dr2424e.html
Support center below, try contacting them direct and get a service and repair manual.
The best way to fix it, in my opinion, is to contact the manufacturer,and ask for a local repair agent, then when there ask for a "Quote" for the repair before proceeding, this way at least you will be able to make an informed decision.
http://www.xantrex.com/support/web/id/1088/support1.asp
7/26/2010 6:43:02 AM • Xantrex... • Answered on Jul 26, 2010
I have a Freedom invertor/charger 458 in my
Buy a long phone cord or however long youneed. Run it temporarily to the remote board and the invertor. Make sure powrr is off during this stage.If this doesn't work the solution is probaly going tobe much tougher. See manual.
Here is the owner's manual.http://www.donrowe.com/user_guides/xantrex/fdm_basic_remote.pdf
2/21/2010 5:03:44 PM • Xantrex... • Answered on Feb 21, 2010
Xantrex Technology DR3624 Inverter/Charger Logo
Popular Tags
34 questions posted
Top Xantrex Technology Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Xantrex Technology Electronics - Others
Most Popular Question
access battery equalizer xantrac dr 3624
  • Electronics - Others
