20 Most Recent Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Questions & Answers
It seems that one of the pieces (possible a set
Its possible your set screw has come out. If you can find the holes to line it up Just keep turning the handle till you see a hole on the inside and get a screw to go into it. Really not sure if this will repair it without seeing it.You may need a bright flash light to see this. If there is still a screw in the handle its possible it may have broken off and needs removing to find the hole on the inside.
12/22/2017 9:10:39 PM • Minn Kota... • Answered on Dec 22, 2017
0answers
Ipilot remote
Be the first to answer 5/24/2014 3:33:40 AM • Minn Kota... • Posted on May 24, 2014Be the first to answer
Prop spins when out of water but when i put it in the water it slows down to a slow creep
yes very common, have you hit a rock as some stage or maybe it is wearing out but as soon as some pressure goes on the prop the shaft will spin normally but the prop is now no longer held to the shaft correctly hence your problem. Check it by marking the prop and shaft with a straight line then put it in the water, take out and check your mark they probably wont line up anymore. Solution...get a new prop. I have a different way to get these fixed but it is not recommended I drill a self tapping screw into my props just until it hits the drive shaft then stop just enough pressure to keep to stuck to the drive shaft
4/9/2014 3:59:35 AM • Minn Kota... • Answered on Apr 09, 2014
Gear puller
4/9/2014 2:44:18 AM • Minn Kota... • Answered on Apr 09, 2014
Minn Kota rip tide st 55 very noisy
is the prop shaft bent you may have busted a magnet in the motor dragging now
12/20/2013 12:33:43 AM • Minn Kota... • Answered on Dec 20, 2013
2answers
What guage wire do we use when going from trolling
6 guage
5/27/2013 1:18:58 PM • Minn Kota... • Answered on May 27, 2013
0answers
When i plug the motor
Check the wires and connectors for continuity, sound like a loose or corroded connection somewhere. Good luck.
1/28/2011 2:56:12 AM • Minn Kota... • Answered on Jan 28, 2011
Minn kota riptide 55 bow
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
10/16/2010 4:02:51 AM • Minn Kota... • Answered on Oct 16, 2010
How does the pin that holds the yoke come out
call the 800 number for minn kota on the motor. they will be able to tell you the best way to remove it on that particular motor. they have a very good tech support system at that company.
5/30/2010 2:28:17 PM • Minn Kota... • Answered on May 30, 2010
I have a clicking noise when I use my motor
That would be the selinoids working[good]......
12/27/2009 8:03:29 PM • Minn Kota... • Answered on Dec 27, 2009
How do you get the prop off when the screw dr. slot is gone.
Used a nut cracker to split the nut.
11/21/2009 5:18:41 AM • Minn Kota... • Answered on Nov 21, 2009
My minn kota riptide 55 stopped working when i
Hi!
To start with, here's a schematic:
RT55 Hand Control
Sounds like key# 87 broke....seen it before.
To replace it, remove top cover, then remove the handle portion by removing the 5 screws underneath. There are a few peices in there, so keep close watch. Also be careful of the fine ribbon wire attaching the handle to the control board...it's pretty fragile.
Best of luck!
Mike
9/27/2009 4:17:53 PM • Minn Kota... • Answered on Sep 27, 2009
Just purchased 2 Optima 900 CCA Marine Batteries,
check for a short in the wire. make sure that positive and negative are right, if unit was working before old battery went bad.are batteries run in series or are they separate. if they are in series make sure they are installed correctly.
7/30/2009 7:58:07 PM • Minn Kota... • Answered on Jul 30, 2009
Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Logo
30 questions posted
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota Boating
  • Minn Kota Boating
Most Popular Question
prop spins when out water but when put
  • Boating
