Refrigerators Logo
Pradeep Banerjee Posted on Nov 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a MAYTAG fridge approx 5 years old. The freezer is working but the main fridge does not cool as well. The tech said I need a new jazz board. Will cost me USD 450/-
If I re-set the damn thing. Will it fix the problem!?
John Tripp
Level 3:
  • Maytag Master 4,656 Answers
  • Posted on Nov 21, 2016
John Tripp
Maytag Master
Level 3:
Answers
4656
Questions
Helped
1679278
Points
14883
What is the model number? Let me price the repair. No you will not be able to reset the refrigerator and the Tech is priced high in my opinion
I have a MAYTAG fridge approx 5 years old. The fre - 26365263-h5ratz2raydzm41lcwpfsh4b-1-0.jpg
1helpful
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
1helpful
The refrigerator is not staying cold. I manually defrosted the freezer coils with a hairdryer, afterwords the fridge started cooling again. But, after a few days, the cooling problem is back. It seems...
first thing to ck ( i would just replace it is defrost thermo pt # ( 67002493 ) and ck the heater pt # 67003426 . and i think you will have solved your problem . how ever were not alway correct so if the problem go on then the main control they cll it the jazz board . the terminator is most likely than the other's and cost less. so first things first .. mm hope this helps . feed back pls ..
Refrigridaire Galleria Refrigerator is not cooling
ck your FAN in back of freezer / and also the dampner in top of fresh food area . if these ck ok the pc board needs replacement ( called the jaz board . ) the jazz board is verry common for your problem .. mm.
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Fridge and freezer not cooling
The main control board is probably damaged. Home owners policy may help pay for it.
2answers
Not cooling properly
probably better off getting a new fridge. replacement could cost £150-250 depending on the engineer replacing it.
1helpful
My admiral fridge freezer suddenly stopped working -
I took the time to look up your Model # and you do have the right board. Jazz 14 Should just be a revision one higher than your origional. Describe to me exactly what happens when you try to program it. You may be missing one little step. Make sure you are doing every step exactly right. I too can miss one little confirmation stroke and it seems like it wont work. I Can email you the tech sheet for your model. This will show you how to test all the sensors, and the damper to determine why the FF side is getting too cold. I will also help on my end as much as i can
2answers
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
