20 Most Recent Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
is the fill tube clog? the ice maker is not going to harvest mode. Take the ice maker cover off and put a jumper on T and H hole the dial will turn and wait until you hear the click remove the jumper. make sure you have gloves on. Do this at your own risk, if you are not sure call a servicer. If the dial won't turn you have a bad ice maker (if you have a 115 volts to the ice maker).
Maytag... | Answered on Nov 23, 2017
I think that that may be caused by a defective 67006294 Dispenser Control Board. .. Item location 13 in this PHOTO. I am here should you have questions, Thanks John T. Appliance 911
Maytag... | Answered on Jun 29, 2015
Digital? Is MFI206AES the correct model number? I cannot find a model number in the US database like that, Sea Breeze
Maytag... | Answered on Aug 19, 2013
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
Maytag... | Answered on May 30, 2013
Hello, You need to look at the screw at the bottom of the handle. I know this is difficult to do; however, you have to establish what type of inset screw you have to faster. Most probably, it is a four or five star screw. You have to have a certain head screwdriver in order to turn the screw in order to secure the handle. When you identify the head of the screw -- as in four or five head screw -- place the screw driver into the screw and turn until it is firm.
If this does not work, refer to the manufacturer's manual to find a solution.
Hope this works for you. Dana
Maytag... | Answered on Aug 15, 2012
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Maytag... | Answered on Feb 25, 2012
use a hair dryer to defrost the line ......
Maytag... | Answered on Dec 28, 2011
I only received part of your problem. Could you please repost the problem along with your model number.
Thank you,Richard
Maytag... | Answered on Nov 19, 2011
Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
38 questions posted
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
icemaker makes ice but want despense
  • Refrigerators
