Home Logo
C
Connie Webb Posted on Oct 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The time , date and temps are correct on my Lacrosse atomic digital clock, but I can not get the day to change to correct day
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Oct 25, 2016
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2700472
Points
29284
Your time may be off by 12 hours or in the wrong time zone.
Testimonial: "Thank you. It was the "12 hour" factor. Appreciate your help."
1helpful
LaCrosse Atomic Clock reset itself to the wrong time zone
Mine does that. i just select another time zone that has correct time and forget it, it is not a big deal.
How do you set an atomic clock
You're not supposed to set the time -- it's supposed to synchronize with the US atomic clock broadcast automatically. Perhaps putting it in a different area of the house, or turning it to a different orientation will help it make the initial connection.
If it still won't, here are instructions from one of the LaCrosse models... use them or go to http://www.lacrossetechnology.com/clocks/atomic-digital/wall/
and find your particular clock, then download the instructions.
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock. Note: In 12 hours mode the time will be displayed with an additional "PM" for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1.
2. Set the desired hours by pressing and releasing the + key followed by pressing the SET key.
3. Now the minute digits will start flashing.
4. Set the desired minutes by pressing and releasing the + key . If the + key is held, the units will increase by 5.
5. Press and release the SET key to move to the "Year Setting".
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the next hour.
WWVB reception occurs daily at 12:00 am and 06:00 am. If the reception is not successful at 12:00 am, then the next reception takes place the next hour and so on until 06:00am, or until the reception is successful. If the reception is not successful at 06:00 am, then the next attempt will take place the next day at 12:00 am.
The other times WWVB reception takes place are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
4helpful
2answers
How do you manually reset a Lacrosse Atomic Clock. Ours is always 4 hours behind and has not caught up. We already changed the batteries.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
3helpful
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
3helpful
3answers
Want to set the clock
Each time you press the set button on the back it selects one of the items that you can set. For example if the "month" is selected by pressing the "set" button then press the "+" key to change it from 1->2->3->4 etc. Each time you press "+" key the month will go up by one. Stop when you reach the correct month. You can do the same for each item including the time zone and daylight savings time and whether you want your temperature to be in Celcius or Farenheit. Hope this helps...
FixerUpper
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
