Been in storage and seems to have seized up I've tried oil and wd40 what else can I do
Ooh, do not use WD-40 or old sewing machine oil. WD40 will work for a short time but turns to gunk quickly and just add to the current problem. The old oil has solidified and turned to glue.
Pick up some liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Apply 1-2 drops every place that metal rubs on metal. Do NOT oil belts, synthetic parts, or tension disks.
Then direct heated air from a handheld hairdryer into the internal mechanism. You may have to repeat alternating lube and heat. If the oil has solidified and seized, this activity should loosen it.
In the future, be sure to keep the machine cleaned and lubed (even when in storage). An overlocker requires more frequent lube since it stitches so much faster than a sewing machine. If you want, you can pick up oil that is especially for sergers--it is usually a lighter weight than regular sewing machine oil.
