Jeep 2002 Liberty SPORT Logo
K
Kim Bethel Posted on Oct 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Location of reset fuel switch for 2002 Jeep Liberty Sport
We had an accident, hammered the front end, and had to replace the radiator and now it won't start....
Marvin
Level 3:
Top Expert:
  • Jeep Master 85,242 Answers
  • Posted on Nov 28, 2016
Marvin
Jeep Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061310
Points
266281
Jeep doesn't use a fuel pump reset AKA "Inertia activated fuel pump cut off switch" You have what is called the ASD relay under the hood that will trip the pump power in a crash. Follow the link for more info on the ASD Symptoms of Bad or Failing Automatic Shutdown Relay YourMechanic Advice
1 Related Answer
jerardi
David Payne
  • 14162 Answers
  • Posted on Jun 19, 2015
SOURCE: 04 jeep liberty sport. Replaced bcm and the first time we locked the doors with the switch and try to unlock with the key the alarm goes off. Nonstop. is there a key sequence without using remote?
Where is the position of radiator fan relay on jeep liberty 2006
no idea to be honest earlier jeeps had then at the front of the wing down below as i remember ?? newer one would i imagine be in the electrical box under the bonnet near the battery
2002 jeep liberty sport will not start. It won,t even turn over. drove it yesterday no problems. after 1 hour tried to start didn,t work Can you help?
Have you tried to jump started ? If your jeep starts when giving it a jump, you may have a bad battery. Check fuses for fuel and ignition systems. If your battery is bad, could be because the alternator is not charging it. Might want to have this component tested.
Where is the bleeder screw for the heater located? Heater blowing warm air, I think I have an airlock.
Bleed screw, jeep liberty limited, 2002, 3.7 L, no heat - Fixya
www.fixya.com/cars/t14960103-bleed_screw_jeep_liberty_limited_2002
Nov 10, 2012 - bleed screw, jeep liberty limited, 2002, 3.7 L, no heat - Jeep Cars & Trucks question. ... Open Question ... Feel radiator and heater hoses, should be very warm to touch,if hoses ... Where is the location of the slave cylinder in a Jeep Liberty2005 ... Bleeding air out of a 2003 jeep liberty sport with a 3.7 motor.
Jeep Liberty - YouTube
? 7:17
https://www.youtube.com/watch?v=Nv0HpH2ymB4
Jan 24, 2014 - Uploaded by 1A Auto Parts
http://www.1aauto.com/1A/ThermostatHousingRel/Jeep/Liberty/ ... What no engine heater install 2007 3.8 j wrangler video ....When opening up the bleeder valve, do you just keep it crackedopen until you have no air bubbles ... already replacing the water pump at 138,000 on an '05 Liberty Limited 3.7L..
Heater only blows hot air intermittently.
Jeep Liberty heater not blowing hot air Questions & Answers ...
www.fixya.com > ... > heater not blowing hot air > Cars & Trucks > Jeep
Jeep Liberty cars & trucks heater not blowing hot air questions and answers. Ask your Jeep heater ... My 2005 Jeep Liberty will not blow heat through ... properly.
jeep liberty 2002 heat problem/hvac box issue - YouTube
? 3:12
https://www.youtube.com/watch?v=xf22fvcN1hU
May 28, 2013 - Uploaded by Joffre richer-desroches
Joffre richer-desroches. ... How To Install Replace Engine Coolant Thermostat and Housing 3.7L 2002 ...
How do you turn off hazard lights on 2003 jeep liberty sport when they won't stop blinking?
For a temperary fix, you can remove the flasher. Makesure it is the one to the flashers and not the turn signals. Probably need to replace the multi-switch in the steering column.
Fuse location diagram for 2002 jeep liberty sport
These are common for the instument clusters to go bad. There are places that can rebuild it or you may have to replace it all together. There is a self test you can run by: key off, push and hold odometer/trip button and then turn the key on while holding the button *don't start it though*, then release the button and it will automatically start the self test. It will show a series of digits and then the software version #. After 5 beep tones it will automatically exit the self test mode. During the test, you can observe the speedo and fuel gauges to see if they are working.
4helpful
How to replace radiator in 2002 jeep liberty sport
Disconnect the negative battery cable at battery.
Drain coolant from radiator
Remove the front grill .
Remove the cooling fan from the engine, if equipped.
Remove the two radiator mounting bolts.
Disconnect both transmission cooler lines from radiator.
Disconnect the connector for the electric fan.
Disconnect the power steering cooler line from cooler.
Disconnect the radiator upper and lower hoses.
Disconnect the overflow hose from radiator.
The lower part of radiator is equipped with two alignment dowel pins. They are located on the bottom of radiator tank and fit into rubber grommets. These rubber grommets are pressed into the radiator lower crossmember.
1helpful
Where is the location of the thermastate on my 2005 jeep liberty sport 3.7 6cyl engine
The thermostat is located in the metal housing at the end of the top radiator hose where it connects to the engine mainifold.
The hose is held onto the thermostat housing by a clamp.
The thermostat housing is bolted to the manifold with two bolts.
Top Jeep Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
David Littlefield
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
