Dryers Logo
Darren Bombardier Posted on May 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Electric Dryer 592-89057 makes a horrible squealing for first 2 minutes of dry cycle. Noise goes away after this point. Is there a repair kit for belt/bearings/bushings? I'm assuming this is the problem Is there an instructional video on how to disassemble the dryer? I've only seen them for older models to date The instruction manual http://www.sears.ca/manuals/div-26/26_C970_89062%20%20%20%20970-C89062_00_89092%20%20970-C89092-00_BOM_2009.pdf was less than helpful with any service related information that wasn't 'call sears techs'. Any help is much appreciated, Thanks!
David Ellis Rhea
Level 3:
  • Kenmore Master 3,462 Answers
  • Posted on May 19, 2016
David Ellis Rhea
Kenmore Master
Level 3:
Answers
3462
Questions
Helped
786335
Points
10903
I am quite suspicious that the problem is a worn out, or dried and hardened, drive belt.
New belt are available in many places, and on-line if you wish to buy there, I buy both locally and on-line.
As far a s changing it, although it is easy, you still must take the machine apart partly to do so.
I recall you should be able to look at an old instruction and transfer that information to a newer one.
They have not really changed much.
God bless your efforts.
Testimonial: "Thanks David for the quick response. Any way I can verify that it is only the belt? I'd prefer to only have to take the machine apart once!"
Dryer makes loud rattling noise while drying
How old is your dryer? My dryer was making a horrible rattling noise and it turned out to be the idler pulley.
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
My dryer is making a horrible noise when turned on and then when the cycle is stopping. the noise continued to happen then began going through the whole time cycle. The dryer is getting hot but it is not...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
1helpful
2answers
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
