20 Most Recent
Whirlpool LEW0050P Electric Dryer Questions & Answers
Power Button will not turn on.
Verify proper line voltage is present at the outlet. This will require the use of a voltage meter. If not properly trained, I would consult an electrician to verify the voltage.
Part of the troubleshooting proceedure requires the technician to verify that the applience is receiving the required supply power.
This has to be verified at the outlet to eliminate the possibility of a bad breaker or bad connection inside the breaker panel or outlet box.
Hope this helps in finding the solution to your problem..
Thanks and good luck..
3/6/2022 5:30:08 PM •
Whirlpool...
Answered
on Mar 06, 2022
I'm installing a drive belt
if it is a rubber belt like a big "O" ring it is necessary to warm up the rubber by stretching it (like you are building up your abs)
it will be tight to fit but it will go on
7/2/2017 10:13:15 AM •
Whirlpool...
Answered
on Jul 02, 2017
Loud Noise when dryer is running.
Don't run the dryer until it is repaired iot will damage a lot of other things if you do. depending on the make and model . most are repaired through the front of the dryer the top comes up and front panel pulls off the blower is screwed onto the motoir shaft some are clockwise and some counterclock wise most are counter. always unplug before working on
12/1/2013 9:08:34 PM •
Whirlpool...
Answered
on Dec 01, 2013
The blower is not coming on?
Sounds like the blower motor needs replaced...... Although if its a matter of no heat then you can change the heating element inside the dryer fairly easily
10/15/2013 6:35:21 PM •
Whirlpool...
Answered
on Oct 15, 2013
