Dyson Cinetic Big Ball Animal Bagless Upright Vacuum Logo
E
Eddie Rutt Posted on May 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blow by , on canister
There is a small blow by on canister mine is not sealing and blowing by?? What do I need to do to fix?
  • Official Brand Answer 2,572 Answers
  • Posted on May 19, 2016
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1770544
Points
6009
Hi Eddie, it's Jack at Dyson.
I'm sorry to hear you're concerned about your Dyson canister, but from the information you've provided I'm not clear on exactly which part you think may not be sealing correctly.
The quickest way of resolving this would be to call our experts directly so we can help further. If a repair or a replacement part is needed, we can confirm whether this would be covered under your Dyson warranty.
You can reach us by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
1 Related Answer
Anonymous
  • 372 Answers
  • Posted on Oct 16, 2008
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
My numatic nvh 370, when I turn it on to use the air at it blow out smells, Why is that? Please thanks
If any moisture has entered the vacuum at any time then this will cause a musty smell. Does the primary filter have discoloration or a yellowy stain on it? this usually indicates moisture has been present at some stage. Replacing the filter may help or you can place a small sachet of air freshener beads (glade) in the bottom of the canister under the bag. This will give a pleasant smell whether vacuuming or blowing.
How do I blow up an r mattress with my hoover agility cyclone vaccume??
If there is a hose or an exhaust port, attach that to the input valve of the mattress and make sure you seal the connection. You may have to use some duct tape. Turn on your vacuum after you use a clean bag or canister.
Nov 16, 2014 • Vacuums
Does the vax 2000 need a bag
Yes, this uses a Bag. AF482 Starbag from Cleanstar.
if the bag is not in properly or damaged it may blow thru.
1helpful
My hose is on the suction side of the Ridgid Dry Vac but its still blowing out of the other hole. How do I fix this?
it is supposed to blow out the other hole. in order for a vacuum cleaner to suck things up, it also takes in air. That air passes thru a filter leaving the debris inside the canister, and then exits thru the other hole.
Sep 29, 2013 • Vacuums
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Is a shop vac supposed to blow while vacuuming? We've had this for several years and I don't recall it blowing air OUT while I am vacuuming.
You should have two ports on the shopvac. One that is basically your vacuum and one you can use as a blower. Your hose will fit on both connectors. So yes, it would both **** and blow. This is called a "blow-through" system.
I don't know where to hook the hose to blow up ballons
There is a round plate or cap on the side of the motor unit. this is removable to attach the hose to blow.
I have a vax v-2000u do they all blow a lot of air out off the front of them it blows everything all over and dosent pick up well i have too get tools out to pick anything up
yes, andrea.....if only it could **** as hard as it can blow!! mine blows so hard that it blows all my fridge magnets off my fridge!!
Jan 17, 2011 • Vacuums
Rainbow dc4 vacume
Take off the round flat water seal, carefully, you will have to glue it back on, remove those screw to take off the bottom piece.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
