20 Most Recent
Shop Vac 925-13 Canister Wet/Dry Vacuum Questions & Answers
How do the wheels install
10. You will find four casters (Figure B) and a dolly (Figure C) with your wet/dry vacuum. Assemble as follows:
11. If the casters are not already installed in dolly, insert casters into bottom of dolly by placing stem of caster into holes provided. Ap-
ply pressure and twisting motion until casters snap into place (Figure 1).
12. With cord disconnected from receptacle and tank cover removed, turn tank upside down so that bottom is facing up.
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Mini shop vac
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
Is a shop vac supposed
You should have two ports on the shopvac. One that is basically your vacuum and one you can use as a blower. Your hose will fit on both connectors. So yes, it would both **** and blow. This is called a "blow-through" system.
We inherited the shopvac 16
The foam filter is for use when using the vac. to pick up water. Now you should have a paper filter for picking up dry material.If possible you may want to look inside of one at the store. Hope this helps.
Stinger Wet/Dry Vac
There is NOTHING
To PETMOMBR I recently had the same problem, I contacted Emerson Tool Co to see if a replacement for the blow wheel is available,and sadly it is not. I was told that the Rigid vacs do have replacement parts and some with a lifetime warranty.
Had my vac for approx 10 yrs, I would say I got my moneys worth. In all, I'd say it's a toss, time to get a new one.
Doghairsucker in Glendora, CA
Has a burning smell
Sounds like the brushes on the motor are wore and burning up the armeture,,how old is it?
I just bought a shop
Too much water in the unit causes what you describe. Water should be drained and the unit completely dried between water events, or unit will rust and have shortened life.
Sulfur and rusty water in my well how can i clear
Usually this is from a compromised liner.
Have the well pipe re-lined.
They usually just put as smaller O.D. pipe in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
