20 Most Recent
Shop Vac 584-06-00 Canister Wet/Dry Vacuum Questions & Answers
Shop vac whines when shut off
It may just be the fan slowing down and acting like a siren, or it may be a dry bearing. Take it all apart, clean and lubricate. Replace the carbon brushes perhaps whilst you are in there.
3/3/2022 5:26:29 PM •
Shop Vac...
Answered
on Mar 03, 2022
Shop vac is not pumping
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here:
https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is
not kinked at any point along the line from the vacuum to the outside.
If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
7/27/2021 8:10:18 AM •
Shop Vac...
Answered
on Jul 27, 2021
Newer wet dry shop vac ring that holds on filter continually falls off
See if you can determine why this is happening.
I have also had such events, and have found it is sometimes necessary to repair or modify the machine, as the plastic parts can wear, or crack , or whatever to cause this.
You may have to do some "creative" repair.
God bless your efforts.
4/7/2016 6:12:57 PM •
Shop Vac...
Answered
on Apr 07, 2016
Wheels on shop vac will not stay on
Use some Goop to glue them in the holes, that's what I did to mine.
Goop is not real hard to yank out should you break one and have to replace them.
10/5/2014 6:36:49 AM •
Shop Vac...
Answered
on Oct 05, 2014
3333.oh
afaik, Shop Vac only gives a general manual, which you can download off their website. All of their designs follow the same concept.
6/7/2014 4:05:13 PM •
Shop Vac...
Answered
on Jun 07, 2014
