Gateway M305CRV Notebook Logo
Posted on Nov 18, 2007
Printer installation The installation process was interrupted. It said my computer is not supported.
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Nov 18, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
790
Points
13
Please give the name of computer printer and opperating system
Thanks
Jaywizz
1helpful
How to install hp printer in your system and how to beneficial hp support number?
HP printer is the best brand of the series in printers. Its cartridge, hardware, and all product can get very easily. Hp printer is updating itself day by day. It has a lot of versions such as a wired printer and wireless printer.
Installation Process:
At first, you would download the hp printer exact drivers for printer support. Check the model number of your printer and go to the official website and download the hp printer drivers. After installing the drivers click on the setup and choose your product and run as administrator. The installation will automatically start. After complete, the process restarts your computer and get enjoy of HP printer.
Operating of the Hp printer is very easy. Anybody can use the printer if the use or non-technical user.
If the problem still remains so call on HP printer support number 1888-315-9712 and get support according to your issues. HP printer technical support team is available 24x7.
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
1helpful
2answers
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Installation stops after the command "installation"
Maybe you the downloading process of your driver was interrupted during the set up.... Try to unsinstall the application and install it again.... and be aware of your antivirus sometimes it detects treat in a driver you installed
5helpful
3answers
Lost my installer. i reformat my computer. how cn i install the printer without the installer HP Deskjet D2360
WordPerfect Printing Problems with HP Photosmart C5550
It's not the program, but the actual printer.
You see, when you print with an inkjet, the information is fed line-by-line through the CPU for processing. The larger the document in size, the longer it takes.
Switch to a color laser printer. They're about 150 dollars. It has an onboard memory and a CPU for processing. Speed wise is about 500% faster. Since it has it's own onboard computer basically, it doesn't need to interrupt the CPU to compute the information and send it to the printer. Laser printers are also known as page printers because they can store pages of information in their own memory.
At the end of the software installation it keeps saying that the process was interrupted and i need to run it again. But it keeps happening. Anybody?
Completly uninstall the driver.
Unhook the usb cable from the printer.
Re-install software and wait till it asks for a port and then plug in the USB cable,.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
