Replace it, order one from repairclinic.com- Ntw4605ewo Parts from RepairClinic com , they often have a video to help as well
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
SOURCE: top load Ge washer model number WVSR1060A1ww will
There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or spinning. I will attempt to cover the basic things that can happen with washing machines.
First thing to check if your washer is not pumping or spinning is to see if the motor is running. If themotor is not runningb>then check the lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
Thank You, Mike Here is also My personal Sight to Help with other problems you might have as well.
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
