Frigidaire FDB520RH Builtin Dishwasher Logo
C
Chloe Gahm Posted on Apr 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cycle did not complete. HEAT DRY light is on and can't be turned off. Start/Cancel button does nothing
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 19, 2016
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290117
Points
2557
Good Morning Chloe, thank you for your inquiry!
Based off the information you have provided me your Frigidaire dishwasher did not finish the cycle and the heat dry light will not turn off. This sounds like there could be a miscommunication within the control panel of the dishwasher. I would suggest performing a reset to help clear out this issue and you can do that by disconnecting power from the dishwasher for at least ten minutes. If the reset does not help it could be a possible problem within the panel or a wiring harness. Best of luck! -Matt
5 Related Answers
Anonymous
  • 750 Answers
  • Posted on Oct 03, 2008
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button as well as the heat dry button and the high temp button do not work. only button that will light up when pressed is the delay button. How can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
Anonymous
  • Posted on Aug 09, 2009
SOURCE: Wont' turn on
Push the "Heat Dry" button for at least 5 seconds. After that you should be able to start your dishwasher. The owner's manual I have says nothing about this, but this is a "lock panel" feature for the electronic panel design dishwashers. I just had this problem and stumbled upon a service manual online. Saved me $75.00.
Anonymous
  • Posted on Jan 10, 2010
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Anonymous
  • Posted on Feb 06, 2010
SOURCE: My Frigidaire dishwasher will not start.
This solution worked for me too. Thanks for the money saving solution!!
Anonymous
  • Posted on Jun 01, 2010
SOURCE: Frigidare fdb1500lfco wont start. Heat dry light
Press and hold the heat dry button and it will turn off, so dishwasher is usable again.
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 • Dishwashers
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore ultra wash dishwasher
Replace control board.
Nov 15, 2017 • Dishwashers
1helpful
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
1helpful
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any...
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Clean light won't turn off, new wash cycle won't start.
Press these buttons in succession, within 5 seconds: high temp wash, air dry, high temp wash, air dry. If the sequence is entered properly, all of the control panel LED's will illuminate simultaneously. Once this happens, press the cancel button twice. Now you should run a complete cycle again. If the dishwasher actually has a problem, it will fault again (means the unit isn't heating properly). If not, it's business as usual.
Apr 25, 2009 • Dishwashers
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
18helpful
2answers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
10helpful
5answers
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
