20 Most Recent Kenmore 24 in. 17262 Built-in Dishwasher Questions & Answers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Kenmore 24 in.... | Answered on May 11, 2014
Is it the clean light flashing?
Kenmore 24 in.... | Answered on Oct 24, 2013
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Kenmore 24 in.... | Answered on Mar 27, 2011
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Kenmore 24 in.... | Answered on Oct 06, 2010
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
oyp8709
Kenmore 24 in.... | Answered on Sep 29, 2010
Start by checking the connections where the power connects to the machine. If it has an electronic control there is a fuse that does open. Eric
Kenmore 24 in.... | Answered on Sep 15, 2009
I just took my Kenmore elite 17262 apart because it was not getting the top rack clean and the soap was not being used up- i.e. low water pressure. The short story - Misc. objects were clogging the screen/grinder, I cleaned out olive pits, a small plastic bag, pieces of plastic and masking tape (from labeled Tupperware) and stringy food, now it cleans much better. Getting to the grinder compartment was tough. A few tips: the top rack drawer slides come out after you remove the stops in front by pushing the buttons and pulling the stops toward the center of the machine. The tube at the back unclips from the ceiling and the back wall and tilts down as you slide the connection out from the supply tube at the bottom. Hold the spray arm and turn the plastic centerpiece clockwise to screw it down through the arm. Rotate the top manifold/supply pipe clockwise 1/8th turn to release; next you will need a small torx (star) driver to take out four screws holding in the screen/manifold. Note where the two nylon washers go on the pivot/axle for the arm. Under the screen/manifold is the grinder cover, remove one smaller torx screw and it will snap out (may be stuck in with accumulated goo). I used a shop vac to clean this area but sponges and tweezers would do, check for damage to the screen and blade. Inspect wash out and reassemble everything in order. The fine mesh screen pops off with a large screwdriver (careful cleaning the screen) Replace the two nylon washers under the pivot/axle and install the supply pipe manifold just before inserting the center pivot, if you put the pivot in first the manifold will not seat. A work light and small parts dish help. Use appropriate force on plastic parts and common sense. If you have hard water try the vinegar trick also (another post) or first. - good luck
Kenmore 24 in.... | Answered on Feb 12, 2009
I have the same dishwasher and the latch has never worked. Finally after 9 months and many service trips I went back to the store and they gave me a new dishwasher. Dealing with Sears has been a nightmare.
Kenmore 24 in.... | Answered on Mar 30, 2008
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Kenmore... | Answered on Jul 23, 2019
Hey, I have a 5 year old Kenmore Elite dishwasher also. Mine started acting up and couldn't figure out why. I finely unplugged it for an hour and plugged it back in, it reset the Electronic broad inside and will work till it happens again. I tried tracing the wires down with the wiring Schematic and couldn't find anything like some kind of fluke some how but unplugging it and waiting works for my problem so who knows it night do it for you and save some big bucks. It's only happen maybe 5-6 times in 3-4 years since new and was out of warranty of course, but I trusted Kenmore for years and years but it works fine after doing that and I'm not calling a repairman for it. I hope it might help, like I said who knows right. Okay. Ben
Kenmore... | Answered on Jul 12, 2019
Kenmore 24 in. 17262 Built-in Dishwasher Logo
22 questions posted
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
kenmore elite 17262
  • Dishwashers
