Vacuums Logo
K
Karen Slater Posted on Mar 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's wrong when it makes constant static noise?
Robert V
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Mar 22, 2016
Robert V
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
25213
Points
297
By constant static noise do you mean a sparking noise? If that's the case the motor may be dying.
How do I stop Eureka Pet Express from making loud noise?
does it make the noise with belt disconected if not its the brush . it could be installed wrong check it.
1helpful
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
I have a DC07 that has a noise that sounds like the noise you here when the brush bar won't turn and the vac is on. That noise that sets your teeth on edge. The brush bar is free and clean, blet...
Dear Jim,
I'm sorry to hear you're having difficulties with your DC07. If you've checked that the brushbar is unobstructed, and the cleaner still seems to be making the noise, I'd encourage you to get in touch with us directly. One of our experts will be happy to provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hear from you.
Kind regards,
Jack
Dyson Online Customer Support
We owe ionic pro turbo air pur. ever since we cleaned it first time, it's making this static noice and it get really loud at times that it makes hard to sleep. What can we do?
Water or debris in the collection blades or wires can cause a snapping or arcing noise. Water should have dried after a day or so. Look for a hair or lint that is between the blades and wires. Ionic also suggests that the noise may be from misalignment of the blades after cleaning. They suggest removing and replacing the blades to reset the position.
http://www.ionicproturbo.com/images/IP_TurboPro_Manual.pdf
Good luck from Detroit.
Mar 02, 2011 • Vacuums
1helpful
2answers
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
