I have looked at your service hints. in the end i ordered a new door lock and installed it. The washer was unplugged for a 24hr. period. upon installing new door lock I am still getting e27 error code and non opperarational.
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
You saved my precious time. I am super grateful.
Thank u. This worked. Now I can spin out my clothes n rwash more.
You're welcome, glad it helped.
SOURCE: installed new door lock still have e27 error code
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code You can manually release the latch by removing the lower panel (Torx fasteners, I think) and finding a wire lanyard that releases the latch. However, I had read that there was a diagnostic code that could be used to reset the latch solenoid via the control panel. There is no service manual available on line, as far as I can tell. Here is what worked... 1. Set the knob to off. 2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously. 3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position. 4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
.Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
You first of all need to
check the pump filter. This is
located at the bottom front right of washer. Look for a drop down flap or cover, once
located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and
junk. The pump itself is directly behind
the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is
water in the washer, just some kind of precaution, so don't force the door.
Pl click helped, if helped
HI THAT MEANS door is locked and will not start PLZ VISIT THIS LINK
http://laundry.manualsonline.com/support/bosch/washer/error-code-e27-3495138
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
