Timer on washing machine turns but does not wash cycle
if water comes in but motor does not engage,probably the lid switch is the culprit.if you hear the motor turning but there is no movement,suspect a bad belt.if water does not come in @ all -verify that the units water supply is turned on.if water is on u probably hear a low humming noise indicating the valve is getting voltage, but no water can get through.remove hoses and clean grit and grime from valve filter screens. if no grit or grime. replace water valve on machine
