Manually eject the disc tray
- Disconnect the power cord and any other cables connected to the console.
- Uncoil a paper clip.
- Position the console horizontally, as you would position a DVD player.
- Find the yellow sticker behind the vents on the left side of the console.
- Insert
the straight end of the paper clip into the eject hole which is located
just above the yellow sticker (as shown in the picture below).
- The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note
If a disc is in the tray, make sure that it is not sticky and does not
have a label that might prevent the tray from opening again in the
future.
If you cannot get the disc tray to open, please see the following article:
906936
The disc drive of your Xbox 360 console does not open
Back to the top
Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
- Unplug the power and A/V cables from the back of your console.
- Position your console horizontally, as you would position a DVD player.
- While holding your console firmly, push the faceplate away from the console with your thumbs.
Note You will need to use some force to remove the faceplate.
- If
your console has holes below the right side of the disc drive, insert
the straight end of the paper clip into the hole as shown in the picture
below.
If your console does not have the holes pictured below, skip to step 5.
- Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
- If
you're successful, the disc tray will pop out slightly. Pull the tray
out the rest of the way with your fingers and skip to step 9. If the
disc tray does not open, try the next step.
- Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
Note Make sure you are pushing the gear mechanism and not the metal plate.
- If
- If
the disc drive is still stuck closed, insert the paper clip into the
adjacent hole (to the right) and push again. If you're successful, the
- Now plug the power cord into
the back of the console. Press the eject button to open and close disc
drive. If the disc drive works properly, reattach the console faceplate.
Note
future.
If you cannot get the disc drive to open, please see the following article:
906936
Back to the top
Xbox SupportPlease visit the following website for information about how to contact Xbox Support:
support.xbox.com/pages/contact-us.aspx
