Televison & Video Logo
A
Anonymous Posted on Jan 07, 2016
Hi I got a free Hitachi 54 inch TV from a guy on Craig's list. He said it works great, but I can't seem to get a pic. It was made in 2004 model number is 57F510. I've tried scanning channels nothing.
Level 3:
Top Expert:
  • Hitachi Master 76,851 Answers
  • Posted on Jan 07, 2016
Hitachi Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008547
Points
237762
You've been trapped. A good friend indeed; who gave it to you. !!!!!!!!!!!
Give it up; man. Otherwise, you might have to sell your home to make this TV to get repaired.
5 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Aug 01, 2008
SOURCE: Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Anonymous
  • Posted on Sep 09, 2008
SOURCE: Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Justin Washburn
  • 116 Answers
  • Posted on Dec 13, 2008
SOURCE: hitachi 55 inch plasma tv
what type of connector are you using fo your xbox? I think
Anonymous
  • Posted on Feb 20, 2009
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Anonymous
  • 45 Answers
  • Posted on Jul 28, 2009
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
54" TV HD MITSUBISHI TRN BY IT SELF...HELP
If a Mitsubishi (Proton is what is listed here) look on the back for the correct and full model number, no 54 inch sets, 55,60,73 etc.
Let me know if power light comes on for a few seconds and then goes off............
1helpful
The audio in Hitachi 62 in rear projection tv was intermittent and now it gone completely, I just replaced the Convergence chips because it had the 3D color separation ,i was able to fix that problem , now...
Model number 55VG825 IS NOT 62 INCH SET, IT IS 55 INCH DLP.
WHAT IS ACTUAL MODEL NUMBER OF YOUR TV?
I can give more information if you give me correct model number---if convergence is now working, it has nothing to do with sound unless you created the problem when you repaired it.
The more info you give me the better I can help you.
I am here to help people, I do this here for free.
SD TECH
Hitachi 55 inch plasma tv
Panasonic 27 inch color tv.
These guys have that part listed in their catalog on this page. It's a long page, so scroll down to it around the middle of the page. Looks like it lists for $209.19, and they have online ordering. They say it's not in stock, but from the looks of them they could probably get it for you no problem. Good luck!
White dots appearing on tv screen
Will need model number, but sounds like digi board problem
Craig www.classtorations.com
My craig tv model ctv-41301 wont turn on
That means that there are solid state components on a printed circuit board that are soldered into place. If the set is a 13 inch it would not be feasable to drop any cash into it as there are 13 inch combo TV sets going for as little as 59 bucks. Good Luck
Greetings from Belize take your set to a tech your tv is having a power supply problem.thats what you call a dead set.good luck.
Hitachi Multisystem TV model # C2980FS ..not powering on
First off you gotta tell us whats the right model and make as you have two listed here and both of these flybacks are avail. trough http://www.partstore.com. The parts are not listed online but get the toll free # or leave a message for them to get back to you. Now A flyback is not a user replaceable part for starters. It is soldered in and theres very high voltage inside these sets even after they are unplugged, and its not adviseable to replace a hi-voltage part in a set, unless you know the issues involved with replacing such parts. Good Luck
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
