Sewing Machines Logo
Sam Reed Posted on Dec 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
I have a necchi super nova that keeps breaking the thread at the needle i need a diagram of how to thread it
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Dec 24, 2015
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2619390
Points
59176
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
1helpful
I bought a 2nd hand Necchi Lydia3 544.Tried stiching but needle thread keeps breaking. Could thread quality have anything to do with it?
Yes quality of thread could definitely affect sewing, as will a blunt/old/wrong size needle for the material used. Also must have same thread in bobbin and needle also corect thread and needle size for material sewn plus correct tension for that material too. Could be lint or tangled threads underneath needle plate too.
1helpful
Why does'n the needle catch the bobbin thread on Necchi BU Nova
Your hook is moving correctly. Not all machines do a continuous circle. If it's not catching the thread, the timing is off. It's a great machine, and worth every penny to have it serviced.
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Necchi royal series
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Neccie BU Nova skips stitches timeing has been checked
have you checked the needle to see if it's damaged
check also to make sure the needle is inserted in the needle clamp correctly
some times the needle & thread are not compatable---- try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Why does the thread keep breaking ?
The most common reason is the needle not inserted correctly (backwards), other causes can be burrs on the needle plate opening or burrs on the parts in the bobbin area.
Jun 02, 2010 • Necchi 6011
1helpful
The top thread keeps braeking. This is a recent problem. I use singer needles. I live in South Africa. I dont get necchi needles.
Usual causes are:
Weak or inconsistent thread..
Threaded wrong.
Needle installed backwards or not seated.
Incorrect tension or contamination in the tension control.
The key to finding the problem is to manually turn the machine through cycles and watch at what point the thread breaks or is strained excessively.
5helpful
2answers
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
