Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
