How to fix it Forbidden
You don't have permission to access / on this server.
Additionally, a 404 Not Found error was encountered while trying to use an Error Document to handle the request. ?
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
This is a response from the Youtube server, saying it cannot find what was asked for. Many Youtube clips disappear unexpectedly, because of copyright infringements or other problems.
Try to play another video if that shows 404 error so it means there is some problem in your internet connection. And if the video play so it means the video whcih you want to play before and showing 404 error is removed by the copyright rules violation on you tube.
Usually 404 is a forbidden domain port. If you are in an office under a internet server than surely the tech blocked the port that good would gain access. If you are at home then the configuration is in your your routers DHPC server and Google is blocked.
HTTP Error 403 is an error message which means that you are not
authorized to view the web page which you are attempting to load.
Usually, the HTTP error 403 - Forbidden means that
access to the file/folder you are trying to open has been denied, either
on intention or owing to a configuration anomaly. You could attempt
using a proxy website if the access is blocked intentionally.
It is absolutely to do with permissions.
Either the wrong authentication type, the wrong username and password or the server is set up to accept connections from only specific locations - such as local host.
You will have to investigate all these options - Uname and Pwd are obvious first choices then server access - then finally I would look at authentication type
it means that there is a forbidden error... it occurs if u use the wrong link or if there is no response from the server due to some reason (like busy server)...
