Does operate by hand turning
Did you read user's manual? Singer Simple 3116 manual
Is the light on? If so, then it is plugged in correctly. Check that the foot pedal is firmly plugged into the machine. Absent that, the foot control or its cord/plug could be faulty or your machine has an electrical problem.
Consult your owner's manual in the Troubleshooting Section for a possible solution.
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
SOURCE: New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while? It sounds to me like the screw that holds the needle in place is loose. As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely. Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell. as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
SOURCE: Singer sewing machine will not operate. push foot
Make sure that your bobbin winder is pushed all the way to the left (sewing position) and that you have selected a stitch pattern and the length is not on zero.
SOURCE: The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
