20 Most Recent
Brother XL-3030 Electronic Sewing Machine Questions & Answers
Bobbin trouble
Never use bobbins that are not made for your machine.
Possibility of further damage is high using parts meant for a different machine. Get the correct bobbins, clean the hook area where the bobbin thread is picked up. Use a tooth brush in and around the area where the bobbin fits.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Why won't my needle catch the bobbin thread
this happens to me when i have put my bobbin in upside down (i know sounds nuts) but yes it is possible for it to be in wrong, take it out and turn it over make sure you feed the thread as shown on your machine ...pull the needle thread tight and turn it will catch if its the right way up and threaded right...good luck
My Bernina E65 will not turn on. No power to the
1. check the outlet2. make sure the power cord is plugged into the machine snuggly and correctlyit also possible that the power cord went bad and that the machine needs to be checked to see if there is something wrong with the power cord or the plug in the sewing machine. or if there is something wrong with the on off switch..
Needle come unthreaded
try changing the needle--it's possible that something is wrongwith the tip of the needlecheck on the needle plate for burrs--if you find any gently use a fileto remove them--but not enough to damage the needle platealso check in the bobbin area for burrs
