Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
The tv alone will not show HD picture. You will need a set top box to watch HD programs and channels. You need what is called a Digital decoder box. You may want to purchase a PVR.
because your VCR will not record Digital video or audio.
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities. Daniel Busa DISH Network Customer Service
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
If your PVR has an Optical Output then you will be able to hook that to your SONY DAV-S300. If it does not you will just be able to use the standard analog stereo connections. I included a picture of the Optical port on your SONY DAV-S300.
Is the satellite receiver HD or standard? If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
