Everytime I press the power button, the power light comes on and after a few seconds it comes off, and there is nothing happening. This thing happens to my tv every once a month or twice. But most of the time it happens to my tv, I just keep pressing the power button for about an hour until my tv starts. Do you know any appropriate and easier solution for this problem?
I got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Sun light is the problem the sun messes it up and makes it over heat try moving or close blinds
55vg825 hitachi rear projection won't turn on about 1 in every 10 tries. Usually will after 3 or 4 attempts. Today 20+ attempts and it won't turn on. I unplugged the lamp and plugged it back in...no help.
I'll phone Hitachi tomorrow.
I have the ultravision 50vf820. Does the same thing 3 to 4 times a month. This morning took 5 min nothing but blinking of the light . then I had to go to work. Is there a answer???
I have a 60sx12B/13k that is a 96 model. It too will not come on. I hear the click and see the red light but then nothing. there are lights on the board glowing green.
Hate to trash it even though it is dated because it had such a great picture.
I see ideas of testing picos and cold solder joint as a culprit. Is there a manual on internet that lists where these fuses are on my mode. Also if I just put the board in the oven on high for a few hours will that fix the cold joints(ha).
Mike
Thr three lights on the television come on, flashes a few times then the tv turns off. The lamp has been replaced but the same thing happens.
exact same issue
my tv lights turn colors but picture wont come on for my hitachi
I have this same exact problem with my UltraVision 50UX19K. At first it started just sporadically. Now, I don't think that the TV's worked since April of 2008. I'm bummed. Was given to me by mom, (me step-dad bought it new in the nineties) and I have been watching this tv for over 12 years. Want to get it fixed, but not sure if it's possible, and don't really want to go out and pay 2 grand or more for a tv of comparable size (it's 52 inches).
I HAVE A 10 year old Hitachi 70" Ultravision Model #70SBX74B. For months I have had an annoying flickering of the picture which seemed like a bad cable somewhere. It seemed to get worse or occur more often or on que when writing was flashed on the screen, or when I brought up information through the info button on my cable control. I changed out wires and the problem persisted. It occured when I played a DVD from a separate DVD player or program from cablevision. Picture and sound otherwise was always excellent.
Yesterday I had the TV on and left the room and when I returned it was off. I am unable to turn it on at all now. The outlet is good, and when the power cord is pulled and then reincerted after a few seconds, the red POWER LED will light momentarily along with some Green LED's on the main board inside the cabinet, then they all go dark. No sound or video is ever present. Any ideas. I am technically capable of working on the TV but I would need some direction. I want to guess that something in the power circuit which had been a slightly intermittant (flickering) problem has finally failed altogether. Is this possible and /or do you have any idea?
Thanks in advance.
Frank F.
I have the exact same problem..My hitachis lights blink and then eventually the lamp light stays on and my tv won't come on
Mine is doing the same thing... My DirecTV remote is not working with the TV for any command, since the problem started... So I can get the power lights to come on, but no picture at all... This occured all of the sudden.. No storm, no outage, no problems otherwise..
I have the same issue, i press the power button and the red light (indicating if tv is on or off) comes on then it immediately goes off
