What happens when you change the monitors to the different ports? Does the violet monitor stay violet when it is plugged into the other video port?
I am guessing that the monitor that is violet is using a VGA connection
The most common cause of a monitor displaying a pink or violet color cast is that one of the RGB conductors in the VGA cable is broken, or the plugs are not firmly seated in the sockets, leading to one color not firing on the monitor. Try a different cable. Try plugging it in with DVI instead.
My experience is that after charging for some tens of minutes it will start. But I seem to be unable to charge the battery enough to have it work for long.
i don't have the solution but i experienced the same problem on my olympus 850sw the images turns violet and the pixels are distorted never see this kind of error ever a camera had
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
the iat is part of the maf sensor located in the air filter duct or housing. 6 pin connector. pin one color violet/gray is for iat. pin 2 is c-signal rtn yellow/violet. pin 3 maf yellow/violet. pin 4 maf rtn blue. pin 5 ground black/yellow pin 6 circuit breaker fuse 76 blue/brown
