20 Most Recent Kenwood KDC-MP4032 CD Player Questions & Answers
2answers
RESET CODE FOR KENWOOD CAR CD PLAYER MODLE KDC-MP4033
Unfortunately KENWOOD codes are not available for free from anywhere on the Internet.
Main Dealer or a Decoding Service ( Try Google or Ebay )
12/8/2021 3:31:43 PM • Kenwood... • Answered on Dec 08, 2021
No power on my Kenwood kdc mp 4032
I would use a test light or multimeter and see if you have system voltage at the back of the deck on the power wires. This will tell you whether the problem is with the Kenwood or the wiring and components coming to it. Remember the car has a radio fuse too
6/5/2016 4:23:35 PM • Kenwood... • Answered on Jun 05, 2016
0answers
Wiring diagram
Yellow..12..memory red...12v..ignition orange...illumination black..chassis ground blue..remote..antenna white..front left+ wht/blk..front left- Green.. rear left+ Grn/blk..rear left- Gray..front right+ Gray/blk..front right - Violet..purple..rear right+ Violet..purple..rear right- These are generally standard colors..hope this helps
4/14/2014 7:06:04 PM • Kenwood... • Answered on Apr 14, 2014
0answers
Wiring diagram
Be the first to answer 4/6/2014 3:59:32 AM • Kenwood... • Posted on Apr 06, 2014Be the first to answer
0answers
Unlock code
Be the first to answer 7/10/2013 11:38:01 PM • Kenwood... • Posted on Jul 10, 2013Be the first to answer
How to change the time
Follow the instructions on page 22 of the manual.
8/17/2012 2:46:59 PM • Kenwood... • Answered on Aug 17, 2012
It just started flashing protect
"PROTECT" :- The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center. Reset is a tiny little hole hole to the right of preset buttons along bottom of unit, Insert paperclip to reset to factory settings?
Good luck with it
7/20/2012 1:25:10 AM • Kenwood... • Answered on Jul 20, 2012
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
6/2/2012 11:09:43 PM • Kenwood... • Answered on Jun 02, 2012
I need the code in
One of the following procedures to clear the security code should work:
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing your "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. If your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
push button "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode.
9/18/2011 5:52:48 PM • Kenwood... • Answered on Sep 18, 2011
0answers
Cant get it off of
Did you try pressing the source (src) button?
5/16/2011 5:59:57 PM • Kenwood... • Answered on May 16, 2011
Need to kno how to unlock kenwood sirius mp4032
code for a kenwook kdc mp4032
8/13/2010 5:32:26 AM • Kenwood... • Answered on Aug 13, 2010
How do you use the auxillary input
plug your ipod or what you plugging in to it then press the source button until it says aux then it should work
8/12/2010 10:05:06 AM • Kenwood... • Answered on Aug 12, 2010
Kenwood KDC-MP4032 CD Player Logo
60 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
change time
  • Car Audio & Video
