20 Most Recent LG HBS-700 Bluetooth Headset Questions & Answers
3answers
Lg hbs 730 problems
i have LG HBS 730 wireless headphones. When turning on they connect to my bluetooth and then just shut down. the battery is fully charged yet the headphones act as if it has a dead battery.
7/13/2019 8:15:10 PM • LG HBS-700... • Answered on Jul 13, 2019
3answers
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need: - 1 small soldering iron- one set of new wired earbuds (no volume control or mic... just plain earbuds)- jewlers phillips head screwdriver- one small flat screwdriver or thin flat edge to pry the cover off.- one needle or thumbtackDirections are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.Directions: - TURN OFF HBS 700- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.- remove the screw located under the plugd49d0cf9-a723-46a8-9565-47c904450fdf.jpg- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.5ebd207b-e704-43ba-b2c1-4c0bb3656563.jpg- remove the earbud cup and set aside. (if working on left side, also remove the charger door.) - the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.4865fbac-05ba-4dcd-bd70-b4bb366d79c7.jpg- once case is removed from circut board, you will see where the earbud soldered to the board.NOW FOR THE FUN STUFF...-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire. BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.-solder the new earbuds in place of the old ones. + to + and - to -.-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.-replace the earbud cup, battery door and power switch if it fell off.-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.-Re-insert the screw and plug.DONE!If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)3dd35676-1c86-449a-9cea-c6cfe284e270.jpgI hope this solution was helpful
5/10/2018 7:06:08 PM • LG HBS-700... • Answered on May 10, 2018
How do I open my LG HBS-700 to fix a broken wire?
OK... know that COPPER is really expensive now so MOST earphone cable conductors are really CLOTH with a VERY THIN strip of actual copper wrapped around it. Now you understand why so many FAIL so quickly. The same is true with hard-wire phone cables... it's really amazing that HANDSETS last as long as they do! Soldering a NEW connector may NOT be possible... and if you did get the solder to flow well.. the physical stress factor at the cable/body junction will continue to be VERY vulnerable to damage again. ONE solution MAY be to solder then BACK-FILL the body with EPOXY! But getting that body open without substantial damage may be a real chore! Perhaps a EXACTO knife or industrial razor blade is a good approach? IF your original LG HBS-700 gave you good/long service AND you were happy with it ~ just spring for another because YOU depend on it so much! Anthony
12/2/2017 11:01:55 PM • LG HBS-700... • Answered on Dec 02, 2017
Audio out doesn't work (i.e., like it is in eternal mute).
Welp.... I see a NUMBER of these LGs on eBay "for parts only"... Do not buy one of those... why buy someone else's problems? Hunt for a different Bluetooth and READ the reviews! But surprisingly ~ your LG has 3 1/2 to 4 stars!? Go figure. Anthony
12/2/2017 10:24:34 PM • LG HBS-700... • Answered on Dec 02, 2017
2answers
How do i put my lg hbs-730 into pairing mode
It should automatically go into pairing mode if it does not detect the last device you paired it to when you turn it on. After startup it should say "ready to pair". Make sure all other bluetooth devices are turned off before turning on the HBS730
7/13/2016 2:35:24 AM • LG HBS-700... • Answered on Jul 13, 2016
0answers
How do I put LG HBS 700 into pairing mode
Turn off the headset. Keep the Call button pressed, turn the headset on and wait for the 3 bips (~4 seconds after turning it on). Then release the Call button. The solid blue light will indicate the pairing/discovey mode.
9/18/2015 7:39:27 PM • LG HBS-700... • Answered on Sep 18, 2015
How do you mute this headset? We've tried to press both volume button at the same time but that doesn't work.
As far as I know, the HBS700 does not have a mute function on the headset. The manual is available from the LG product support site: http://www.lg.com/us/support-mobile/lg-HBS700 . The direct link is http://www.lg.com/us/support/products/documents/HBS700_Manual.pdf . Oddly, the microphone does get muted automatically if your device is connecting to a local wi-fi signal. I wish that I had better news for you. Cindy Wells
8/9/2015 11:57:41 PM • LG HBS-700... • Answered on Aug 09, 2015
Have a HBS 700 that pairs with device and was working but now still works but no sound.
check volume control to full,,,,,otherwise speaker inside it=defective
7/19/2015 6:14:06 PM • LG HBS-700... • Answered on Jul 19, 2015
3answers
Off & on button not working
I had the same problem. Because I live in Brazil and this headphone is not sold here (I bought it in Canada), taking it to assistance wasn't an option. I was so annoyed that such a minor issue was keeping me from using an otherwise perfectly working headphone, I went ahead and tried to open it. Obviously I couldn't do it, got mad and ended up ripping the whole thing apart. Luckily I only screwed up the plastic case so it still works. Anyway, turns out it's just a 3mm piece from the external power switch that broke, so it wasn't able to push the internal power switch. I removed the external switch and put the (rest of the) plastic case back on, I only need a small tip, like a mechanical pencil, to turn it on and off. If you don't know what else to do and won't bother to send it to assistance, I recommend just using something like a utility knife to cut off the external power switch (without opening the whole thing) so you can reach the internal switch.
6/2/2015 6:38:39 PM • LG HBS-700... • Answered on Jun 02, 2015
2answers
How do i fix power button switch on my wireless bluetooth headset? it the LG tone HBS-700
It is possible you may have broken the power switch off of the circuit board. To find out, you will need to open the earpiece and inspect it. Here is a video on how to open the earpiece LG Tone HBS700 730 repair mod and upgrade. If it has broken off, you may be able to solder it back on to the circuit board. If it is beyond repair, you could purchase a broken earpiece for cheap and use this video to repair it. I hope this helps.
4/30/2015 6:30:22 PM • LG HBS-700... • Answered on Apr 30, 2015
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. W
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
3/25/2015 2:56:30 AM • LG HBS-700... • Answered on Mar 25, 2015
What do flashing red light mean ?
Flashing red light means your battery is depleted and you need to connect to a charger.
3/6/2015 4:21:15 PM • LG HBS-700... • Answered on Mar 06, 2015
How do i connet my lg hbs700 from my old fone to a new fone?
Turn the bluetooth radio off on your old phone. Turn on the hbs700. Your earpiece should automatically go into pairing mode when it does not detect your old phone. Turn on the bluetooth radio on your new phone and search for your hbs700. Connect to and you're done.
3/6/2015 4:19:35 PM • LG HBS-700... • Answered on Mar 06, 2015
LG HBS-700 Bluetooth Headset Logo
278 questions posted
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • LG Radio Communications
Most Popular Question
left earbud no sound
  • Radio Communications
