Kitchen Ranges Logo
C
Chris Dagenais Posted on Sep 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven lights do not turn off when closing door or hitting on/off button. What may be the issue? What can I check on my own before calling a repair tech? Tks!
Kenmore Elite C790.440832
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Sep 23, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
259146
Points
4510
The on/off switch is defective.
2answers
KitchenAid oven lights flash and it beeps when one door is open.
if possible, update all of the bulb lights in your oven and check how they respond when you open various doors on your machine.
If everything works, then it was the bulbs that were the issue. If not, then you might need to reach out to Home Depot and/or Lowe's for a home repair appointment.
Thank you.
Nov 10, 2022 • Ovens
Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
1helpful
2answers
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
2helpful
4answers
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
We have GE oven. We never used the self cleaning mechanism, but the designation "door locked" is flashing and we can't complete shut the oven door because the latch is not set properly. How can we reset...
MINE DID THIS TONIGHT. I HIT THE CLEAN OVEN BUTTON AND THE DOOR LOCKED STAYED LIT. AFTER ABOUT 1 MINUTE I HIT THE CANCEL BUTTON AND THE LIGHT FINALLY WENT OUT AND I COULD SHUT THE DOOR. HAVE NOT TRIED TO COOK WITH IT YET SO DON'T KNOW IF THE PROBLEM IS SOLVED BUT THE LIGHT DID GO OUT AND I COULD FINALLY CLOSE THE DOOR.
Self cleaning issues
this may be as simple as pushing in the door/light switch
1. select a clean cycle and start it
2. aftewr you press start, locate the oven light switch (should be somewhere that the door can hit is so light will turn on and off as you open and close the door) keeping the switch pushed in, press the cancel button to cancel the cleaning cycle. the door lock mechanism should then unlock
let me know how this does
38helpful
2answers
My clean light is flashing....call service to check heater?
f the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
3helpful
Hit the clean button while oven door was open
Need 2 people. Turn off power to it. Hold in door light switch. Turn on power. Hold switch until latch stops moving. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
52helpful
8answers
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
