Hi David
I think you should replace the lamp.
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
SOURCE: need to reset the lamp hours on a sony vpl px40
Projector should be in Standby mode
Press RESET, <=, => and Enter keys to reset lamp timer.
That procedure is also mentioned in user manual page-39
Thanks.
