20 Most Recent Sony VPL-EX4 Projector Questions & Answers
"Frequency out of range" when plugged into macbook
Hi Douglas.Try going into your display settings and change your screen refresh rate/display. If your screen refresh rate is too high/too low this will cause your issue. Also check your screen resolution. Hope this helps.
6/7/2017 12:43:58 AM • Sony VPL-EX4... • Answered on Jun 07, 2017
0answers
manual
Where is reset button in VPL EX 4
some models has another NOT. However you must read your owner manual or download from www. fitness.manualsonline.com or www. retrevo.com Merry Christmas
12/20/2013 12:21:25 PM • Sony VPL-EX4... • Answered on Dec 20, 2013
0answers
Factory reset
Be the first to answer 12/19/2013 3:33:22 AM • Sony VPL-EX4... • Posted on Dec 19, 2013Be the first to answer
2answers
Our Sony VPL-EX4 Projector keeps shutting itself
Check fan cable
5/24/2013 2:00:48 PM • Sony VPL-EX4... • Answered on May 24, 2013
2answers
Please send me circuit diagram
I have a copy of the service manual which contains service information - electrical adjustments - troubleshooting - spare parts - block diagram - frame schematic diagram. If you want the copy, let me know your email add and I will send it to you for free.
Jdvillanueva
8/18/2011 12:25:05 PM • Sony VPL-EX4... • Answered on Aug 18, 2011
Hi, I work in a
You can make all sorts of adjustments. From your description, it sounds like the contrast and brightness are mis-adjusted.
If you do not have the manual, you can download it from here.
Best of luck, Jim
3/8/2011 9:10:04 AM • Sony VPL-EX4... • Answered on Mar 08, 2011
Blinking power on switch 4 times what is the error
PROBLEM: The fan is broken
If any fan in the projector not move, broken, jam, the power light blinking 4 times after few second of power ON
SOLUTION: Remove the filter and then remove the upper cover
check fans and fan connector
if all fans are OK then remove the fan connector and reinstall
fix the cover and power ON projector
2/10/2011 2:39:31 PM • Sony VPL-EX4... • Answered on Feb 10, 2011
I need drivers for sony
Data projectors don't need any drivers.
11/9/2010 12:11:11 PM • Sony VPL-EX4... • Answered on Nov 09, 2010
NO PIC LEN OF
if you are using a laptop,hold down function and press the display key until it clones both screens,if you are using a computer,make sure the connections are secure,also try and make sure that the source is from the computer/laptop and not s-video or component video.
also try replacing the vga/dvi cord.
5/8/2010 11:22:41 AM • Sony VPL-EX4... • Answered on May 08, 2010
Data projector is not turning on. How can I
open up the top case. the fuse will be on the power supply board right next to where the power cord plugs in. you'll need a continuity tester to test it. if it is blown, replace it with the exact size and type. if it is not blown, replace the power supply.
2/3/2010 6:53:23 PM • Sony VPL-EX4... • Answered on Feb 03, 2010
Sony VPL-EX4 Projector Logo
31 questions posted
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
blinking power switch 4 times error
  • Office Equipment & Supplies
