That is an internal electronic failure. Could be a ballast, mainboard, any number of things. Not a user repariable issue. http://www.projectorcentral.com/pdf/projector_manual_3594.pdf
More info is on page 47 in the manual that I linked.
SOURCE: Infocus lp580 will not come out of standby mode
these have a timer for the lamp hours, but that doesnt mean the lamp is bad, under the unit there are directions to reset the timer when you replace the bulb. you can follow those directions many times before the bulb actually expires.
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TV will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
