20 Most Recent Sony VPL-EX1 Multimedia Projector Questions & Answers
Sony Care is the better choice!
Sony VPL-EX1... | Answered on Apr 26, 2014
the filter cover sometimes gets distorted and the small plastic dimple which presses against the switch doesnt activate correctly, check the lamp cover switch also.
Sony VPL-EX1... | Answered on Nov 04, 2013
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Sony VPL-EX1... | Answered on Sep 08, 2013
Go to MENU, INSTALL, and then use FLIP to reset the projected image to match with your installation.
Sony VPL-EX1... | Answered on Apr 20, 2012
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Sony VPL-EX1... | Answered on Jan 17, 2011
1.unplug power cord
2.plug back in and it should be in stand by mode.(red light on)
3.do not power on
4.on remote push RESET,LEFT ARROW,RIGHT ARROW AND ENTER(do it in less than 5 seconds)
5.after you have done this power on and go to menu and it should show lamp hours 0
6.if it didn't work just do it again, it took me a couple of tries.
Sony VPL-EX1... | Answered on Jan 06, 2011
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Sony VPL-EX1... | Answered on Oct 29, 2010
hello,it is either it is not well fixed,i will advice you replace the lamp.you can kindly visit the link below to see how to fix the lamp,
http://www.youtube.com/watch?v=9-A154ZVz0I
take care.
Sony VPL-EX1... | Answered on May 26, 2010
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Sony VPL-EX1... | Answered on May 05, 2010
If you have user manual go to page no 27 and follow the instruction
Sony VPL-EX1... | Answered on Mar 06, 2010
Try replacing the lamp cover with a new one, if that does'nt work then it could be the sencor for the lamp cover, and if that does'nt work then contact your sony dealer and see what they can do.
Sony VPL-EX1... | Answered on Feb 13, 2010
Sony VPL-EX1 Multimedia Projector Logo
33 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
changed lamp
  • Office Equipment & Supplies
