I have a 8gb usb pen drive.when i plug it on to usb ,i get a message"one of the usb devices attached to this has malfunctioned,and windows does not recognise it.for assistance in solving this problem click this message.When I click this message UNKNOWN device is given there.i plugged my usb pen drive in other machines and getting the same message.any way to solve this???plzzz
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
click start control panel administrive tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to
fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust
build up on them dust will cause static and a lot of unforeseen problems for a
computer and its parts hope
this helps
