SOURCE: Center and Surround Channels Inop
Even if it were a fuse, a blown fuse is merely a symptom not the solution. From the symptoms you've described the AMPs are the most likely problem. They are mounted to a large aluminum heat sink usually about center of the main board. There are several and they are a task to remove and replace because the entire board has to be removed... However, it's not too costly a repair and for a qualified shop something that can be done in a couple of hours - including testing. If you like the receiver get it fixed. Compared to most digital receivers today it's probably cheaper to fix this one than buy another. And a good repair shop will add years more life to that unit... Hope this helps. Bill
SOURCE: left channel not working
Probably Broken solder connections in unit. I have seen these units have many poor broken connections throughout amp espcially around poweramp ic .IC701
I have a service manual if you are interested in it [email protected]
SOURCE: Right channel is completely gone
Yep - needed IC repair by Sony - $200 plus shipping though ...
SOURCE: Center Channel not Working
Check that it's center speaker in the set-up menu is on and that the sound field that it's in uses the center speaker. try it in pro logic. It could be a bad solder connection on the speaker terminal or on the relay in the receiver.
SOURCE: NO SOUND FROM REAR OR CENTER SPEAKERS.JUST THE
have you checked the wiring of the speaker some time the can cut internally so to check use a small wire and connect just like the one which is in the manual this Can solve the problem
