Here are a number of reviews-
http://www.harmonycentral.com/reviews/product/samick-lw-015
SOURCE: My neck of the guitar
This is very serious as a broken neck means a lot to the guitar. It depends on the section broken and if the fret is also damaged.
Since the neck needs to be quite strong as the strings are tightened and must not in any way bend or be soft-- as the TUNING WILL KEEP ON CHANGING- the neck must be wedged back and then maybe the use of a counter steel reinforcement might be needed.
It is best to get this done professionally , if you intend to get this guitar to retain the quality.
SOURCE: wire diagram samick gregg bennett guitar
Here is the wiring diagram for a 2 humbucker, 2 volume, 2 tone, 3-way switch setup. The wires off the pickup may be a little different. Just attach the lead wire to the arm of the pot and the ground to the ground on the top of the pot. Should be very strait forward.
http://www.seymourduncan.com/pdfs/support/schematics/2h_2v_2t_3w.pdf
