20 Most Recent ION Audio IED11 Sound Session Complete Electronics Drum Set Questions & Answers
Good job of troubleshooting... I assumed you have tried other triggers into the kick drum input and found it is dead. This leaves the problem in the "brain". Look in your manual for anything to do with sensitivity of the kick drum input. It is likely all the inouts are sampled and digitized by the same A-D convertor via a multiplexor switch. I was unable to find the schematic of your unit so I downloaded one for a Roland TD8. Often the different companies rob designs from eachother so one can glean methods from a different brand. As expected the inouts are conditioned and then go to a MUXX chip that samples the input. The signals are conditioned before going to the MUX by a limiter and before that there is an RF bypass cap on the input. IF you might have had a static discharge, that capcitor(s) may have shorted rendering those inouts dead. This is what I want you to try:with a suitable cable I would like you to pulse the kick input by momentarily connecting a 9 volt batery to it... try both polarities. If NEITHER polarity fires the kick, then I want you to take an ohmmeter and measure the resistance of the input. The Roland schematic has coupling capcitors and if your brand has similar circuits you should see infinite resistance... if you find it very low, say 100 ohms, probablly the RF bypass cap at the input is shorted. These will be surface mounted caps and you need to be a bit adept at electronic repair to replace them. Essentially I believe you will find a failure in teh interface ckt where those inputs come in.
ION Audio IED11... | Answered on Jun 27, 2015
Have you checked that it is not the amp that is the problem? This is a fairly common thing to have the amp heat up and the thermal protection shut it down partly. Since the bass drops, a loose connection or bad guitar cable can cause that. If the signal becomes capacitively coupled only the treble will come through and be very distorted. Try a new cable. For the guitar, open the electronics area and look for loose or broken wire.
Music | Answered 12 hours ago
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered 3 days ago
you found it on search on net
Music | Answered on Oct 16, 2019
The best way is to plug the send to the input then output to return of mixer
Music | Answered on Oct 11, 2019
Too many songs to be specific with your vague clue. Try Google.
Music | Answered on Oct 05, 2019
It would be nice to know what brand name and model you have there......
Music | Answered on Oct 04, 2019
Assuming you are talking about a jack and you are asking this question, pay a tech for this.
Music | Answered on Oct 01, 2019
ION Audio IED11 Sound Session Complete Electronics Drum Set Logo
Popular Tags
2 questions posted
Top ION Audio Music Experts
Michial Gueffroy
Marvin
Marvin
Are you an ION Audio Music Expert? Answer questions, earn points and help others
View Most Popular
ION Audio Music
  • ION Audio Music
Most Popular Question
ied 11
  • Music
