Equator EZ 3600 CEE Front Load Washer / Dryer Logo
Andrea Lingle Posted on May 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clean the impeller?
My dryer is taking a very long time to dry clothes and i already cleaned the lint screen
Jorgie the appliance guy
Level 3:
Top Expert:
  • Equator Master 5,639 Answers
  • Posted on Feb 02, 2016
Equator Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523843
Points
32630
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
3 Related Answers
Anonymous
  • Posted on Sep 09, 2008
SOURCE: how to get your EZ to start drying again
thanks, snwbrdr! it's working much better now! thanks. damn ... that thang was DIRTY!
Anonymous
  • Posted on Nov 24, 2008
SOURCE: Drying Issue (help!)
It's lint stuck in the dryer that drastically lowers the efficiency.
From another site I found the solution:
1. UNPLUG UNIT
2, remove 4 screws top back edge of top panel and lift off panel.
3. blower will be toward the right rear of unit. To save a hassle later, take a sharp object and scrib an index mark across where the blower meets the plenum, it will help you line it up later.
4. there are four 7mm bolt-head screws holding the blower and blower motor onto the heater plenum. One of the screw is almost impossible to see, but there are 4. I used a "flex-shaft" socket to get them out. This can be a real PITA.
5. carefully lift blower motor out of plenum. You will probably need to shove the whole tub unit to the left to get clearence. IF YOU OPT TO DISCONNECT THE BLOWER WIRES MAKE A DIAGRAM OF WHERE THEY CONNECT!!
6. I usually use a thin knife to scrape each of the vanes on the blower. Then vac everything out and use your hand to check for smutz in the plenum.
7. THE FAN ONLY FITS ONE WAY ON THE PLENUM. be sure to test fit to see if all the holes line up.
8. When motor is back in place, spin the little cooling fan on top of motor to make sure it's not binding. I usually test the unit by plugging it in and starting dryer to make see it runs.
9. Put top of unit back in place.
Anonymous
  • Posted on May 11, 2009
SOURCE: Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Dryer lost heat
This may be a heating element issue.
If you want to do a few things before calling someone, you would want to start by making sure all of your dryer settings are set correctly. Some dryers have "air" settings or "delicates" settings. These settings are going to be very low heat so the clothes are not ruined.
Also make sure that the lint screen has been cleaned each and every time you have started a new load. If not, you can UNPLUG the dryer, pull the dryer out and with some simple tools, take the back off and vacuum what you can get to. If it's very dirty you'll want to call a professional. You'll need it cleaned and your problem diagnosed. If cleaning the lint screen is not something you have done on a regular basis, then please start. This could be a fire hazard if it is not cleaned regularly.
Another thing to check is your vent or vent hose. Depending on how your set up is, if your hose is crimped behind the dryer and the heat can't escape, the clothes will not be able to dry. This would only be something if you have some heat but clothes are not drying. Also, sometimes due to the age of the hose, previous use, not cleaning the lint screen, etc, the venting from the house to the outside could be clogged. Again, there will be some heat, but the clothes will seem to take forever to dry.
Good luck.
Feb 24, 2015 • Dryers
tip
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
on Feb 23, 2010 • Dryers
1helpful
Gew9868kq0 not drying
Hi it could be that one of your heater element coils blown or a faulty thermostat
1helpful
Does not Dry. Appears to have low air flow.
most of the problems associated with this problem are caused by lint being in vent tube to outside and restricting the air flow. clean out vent tube, from dryer to outside. this should help. repost if need be. good-day ! if you have too. clean out bottom of drier with a vacuum. around the fan and where theres lint trapped.
My electric dryer heats up but does not dry the clothes. I have to run the cycle at least 1hour or more to get the clothes to dry. the clean lint filter goes on every time and there is no lint,the machine...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 24, 2011 • Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
How do I clean the lint out of the system? My cloths aren't drying. It takes 2 cycles to get the cloths dry. I cleaned out the lint trap, but it is still doing it. Is there a web page or instructions...
heatman101
4helpful
3answers
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Top Equator Washing Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
