20 Most Recent GE Profile DPSB620ECWW Electric Dryer Questions & Answers
Ge profile electric dryer dpsb620ec ww
Did u reconnect wires to door switch, or maybe inadvertently pulled them loose.
8/24/2017 1:50:08 AM • GE Profile... • Answered on Aug 24, 2017
Dryer has power, control board lights up and beeps when touched, but dryer won't start
I would check the door switch. if switch is good, then control board might not be recognizing switch as being closed. Check for proper voltage at the plug. any volts under 208 is bad.
11/27/2015 10:40:10 PM • GE Profile... • Answered on Nov 27, 2015
How do I attach the wires on the timer
there should be a plug right there
2/9/2015 2:14:13 AM • GE Profile... • Answered on Feb 09, 2015
0answers
Too much lint
Be the first to answer 1/29/2014 3:21:22 AM • GE Profile... • Posted on Jan 29, 2014Be the first to answer
Clean Lint Filter Light/Possible Heat Problem?
Take the front panel off the bottom and check the big hoses that connect to the drum. From what you are saying, the fan is working but not drawing air through the drum. That is why the light is on because it is not sensing air flow through the connections to the drum.
12/2/2013 5:41:31 PM • GE Profile... • Answered on Dec 02, 2013
2answers
Dryer runs but there is no heat. Reset breakers
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
11/8/2013 1:35:03 AM • GE Profile... • Answered on Nov 08, 2013
manual
manual
Dryer runs for a short period of time and then
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
12/1/2011 4:42:15 PM • GE Profile... • Answered on Dec 01, 2011
Hi, When I turn on my GE profile dryer it makes
did you replace the belt and idler pully and cleaned the fluff from the heater
10/20/2011 1:15:09 PM • GE Profile... • Answered on Oct 20, 2011
The drum barrel is squeaking loudly....how do I
For a quick inspection, the back is easier to remove to gain sight of the potential problem. Make sure the power is off. You will probably find the drum rubbing somewhere and have to release the weight of the drum to check bearings.
8/31/2011 7:42:39 AM • GE Profile... • Answered on Aug 31, 2011
2answers
I have a gas dryer
Check the "thermistor" that is on the blower housing for continuity with a multimeter. It should read 2.27k. If you get any other reading, replace it with this part.
Richard Roth
The FixYa Team
8/14/2011 5:43:20 PM • GE Profile... • Answered on Aug 14, 2011
No heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
8/5/2011 9:01:17 PM • GE Profile... • Answered on Aug 05, 2011
Red light is on and
clean the sensor that is located underneath the lint trap
3/2/2011 10:09:23 PM • GE Profile... • Answered on Mar 02, 2011
Dryer will not dry
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
2/1/2011 11:23:11 PM • GE Profile... • Answered on Feb 01, 2011
GE Profile DPSB620ECWW Electric Dryer Logo
52 questions posted
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
when turn ge profile dryer makes
  • Dryers
