It sounds like two separate problems.
1. It sounds like your magnetron is overheating and then the thermostat trips, cutting the power until it turns off, then it closes to power it back up.
It's essential that the internal cooling fan (I don't mean the hood / vent / exhaust fan) is running to be sure the magnetron stays cool.
2. It also sounds like your vent / hood / exhaust thermostat is sticking or the triac on the circuit board is leaky, causing the vent fan to stay on.
But you may want to check the
owner's manual. It is designed to stay on if the temperature of the stove top is above a certain level.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering
your full model number
here.
There should also be a "mini-manual" hidden inside the
unit behind the control panel or hidden on the left side behind the grille,
which is very helpful when troubleshooting & testing.
-.htmPlease reply back here if you still need help.
-.htm
We're happy to help and we appreciate your
thoughtful rating of our answer.
Hi Jacquelyn West, I want to help you with your question, but I need more information from you. Can you please supply the model number of your oven in the comment box?
