20 Most Recent GE JVM1440 Microwave Oven Questions & Answers
GE Microwave Model JVM192K heats intermittently
Verify the door micro switches.
11/14/2017 9:20:33 AM • GE JVM1440... • Answered on Nov 14, 2017
3answers
While running microwave shuts off randomly and
The only thing that controls the display is the microprocessor on the timer board. Sounds like needs a new timer board.
10/27/2017 7:16:22 AM • GE JVM1440... • Answered on Oct 27, 2017
GE JVM1440 microwave - Fan only works on 'low' speed
Only working on low would probably be either a bad blower motor or a bad main circuit board. I dont remember ever having to replace a blower, but the main board has relays that switch back and forth for what ever speed you are trying to use. Problem is the main board will be quite expensive. May want to look at prices on new units. And remember on a new unit you get full factory warranties on everything.
10/4/2017 9:22:45 PM • GE JVM1440... • Answered on Oct 04, 2017
0answers
Does not cook!
Be the first to answer 7/5/2017 10:13:55 AM • GE JVM1440... • Posted on Jul 05, 2017Be the first to answer
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
4/23/2017 4:10:41 PM • GE JVM1440... • Answered on Apr 23, 2017
Microwave runs but does not heat
Possible Diode most usePossible Inverter board that controls and fires the MagnetronPossible bad Magnetron.12_13_2012_8_48_58_pm.jpgTypical microwave diode.12_13_2012_8_49_38_pm.jpg typical Magnetron
11/25/2015 7:55:12 PM • GE JVM1440... • Answered on Nov 25, 2015
2answers
Braker keeps tripping
I need to know a few things.
1. Did you just place the Microwave in service?
a. If so you may very well have an over laded electrical circuit in your Kitchen. Try moving the uint to anouter cirsuit and see if the breaker for that circuit trips
2. Did this recently start happening?
a. If so then there is an internal short in your microwave.
b. This is usual;ly caused by a couple of things
1) The power diode for the magnetron is shorted
2) The capacitor has shorted
3) A door microswitch has failed in the open position (internlock protection)
4. The magnetron has failed.
These are the most common problems but there is always a chance of having a grounded power wire somewhere inside the chassis. I did not solve anything here but these are the most common problems. Cheers!
11/18/2014 12:48:06 AM • GE JVM1440... • Answered on Nov 18, 2014
0answers
0answers
I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads and without turning power off and shorted something out. Underneath lights and fan will not work. The microwa
I would say you have blown a fuse on the unit. As you now have found out, that's one of the reasons why you unplug any electrical equipment before working on them. You will have to take the outer cover off the microwave and locate where the fuse is. It is most likely on the back of the main PCB or possibly inside a plastic sleeve or mounting near where the cord enters the unit.
2/23/2014 10:17:36 PM • GE JVM1440... • Answered on Feb 23, 2014
What is the wattage
It should be listed along with the model and serial number inside the door frame or on the back side... If it doesn't list wattage, Volts X Amps = Watts.
2/16/2014 9:52:23 PM • GE JVM1440... • Answered on Feb 16, 2014
GE JVM1440 Microwave Oven Logo
245 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
change light bulbs
  • Microwave Ovens
