HP Compaq Presario C700T Notebook Logo
Posted on Jul 10, 2009
Computer works great on battery but will not charge or work on the Power Supply. The power supply is good. Problem seems to be the transistor in the charging circuit. Has the number C-24 and is probably an NPN. Do you have access to this transistor or know the actual number. C24 is probably the Compaq number. Thanks
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
2answers
My acer aspire 6530 suddenly stopped charging the battery, it works with battery, works with battery and main power supply (yet, as long as the battery is still charged), and it certainly doesn't work with...
Seems like this is the case of a bad power supply adapter, and needs to be replaced. But to make sure we are on the right track, you mention towards the last statement, you said that when your laptop is off, and the battery is installed on, and without the power supply, the computer power button would flash and no sign of life right? Well take these step to see if it is the power supply, 1, check to see if the small green light is lighting from the powersupply adapter. If it is not, then 100% you have a bad power supply. 2, does the laptop power on when using the power adapter only, and with the battery pulled out? If not, then 85% still is your power supply and the other 15% is your power jack, either is loose, or bent, as we tend to plug in and out alot. 3, Does the laptop power on with the battery itself without the power supply adapter? If it does, it is not your battery. The reason to the laptop power light blinking with the battery installed only could be that the battery is low/drain and does not have issufiect charge to power up your laptop. And to say that when your system is on and your plug in the powersupply, and the small battery icon says it's charging but actually it is not. It could still be your powersupply, it is damaged but a smart chip installed on your powersupply only sending signal to your laptop, this chip is only to prevent the battery from over charging. So if you have another power supply, you cna test this out. But at this point, they was you described things, I believe it to be the power supply. I hope this help, if you have any question, let me know.
No power with power supply plugged in
I would use a power supply tester to be certain. Voltage meters are a good indicator of weather or not the main power distribution points are working, but there are actually several points providing power.
If this still doesn't work, check the power at the battery terminals to see if the battery itself is getting any power sent to it.
Works great on battery but will not charge or work on the Power Supply. The power supply is good. Problem seems to be the transistor in the charging circuit.
I had the same problem
eventualy the end fell off
i had a look at it and it turns out that the connector, after general use, snaps inside because the connection between the main wire and the connector got bent when i charged my laptop
i am now on my third charger and even that is dodgy
1helpful
3answers
Will not charge
With both above posts above included I want to add my experience with 3 Toshibas.
1. The A75 series was very prone to the power supply becoming loose on the motherboard. Those who are moderately good at DIY projects can resolder this. There are good photos elsewhere to show how. A loose connector will cause the power LED on your computer to flicker, sometimes the machine will turn off, etc. because the AC supply is unpredictable. Unfortunately, Toshiba and others may sell you a NEW power supply, which then can give you a second, and different, problem. The new power supply may not produce enough AMPS for the A75
2. The A75 series is VERY energy hungry and must have a power supply of 19v and 6.3 AMPS. The amps is CRUCIAL. The newer Toshibas run on 3.4 amps and a replacement power supply of the wrong size will show a green LED for power, it will charge your Battery in the system off( i.e computer plugged in but turned off mode) but it will not allow windows to run, even though it will allow you into BIOS setup. This combination means you have to charge the battery in the OFF mode and then when the computer runs, it is actually running from the battery, not 120v AC. The battery then runs down and the sytm shuts off.
So look at the Toshiba Label on the bottom of your laptop and read the correct voltage and AMPS!!! The 6.3 AMP power supply is BIG (6.5x2.5x1.5 inches) and is available new online for about $27.00. This problem solved my power problems on both an A75-S2292 and an A25.
Good luck
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
1helpful
Gateway laptop m465e power supply problem
Hi, My name is Michael Fuller, I'm the owner of Computer Eworld. I have this laptop and mine had the same problem, 2 things are wrong, your bios needs to be updated and your system needs to be updated. If you want, I can fix this problem, it will cost you $35 for the labor, and of course the shipping charges. You can put your request in on the company website or you can call me directly, my number is 662-549-2362. www.computereworld.com well good luck and have a happy new year!
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Seems as you have blown an output. Seek repairs.
6answers
Ps3
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
