20 Most Recent HP Compaq Presario C700T Notebook Questions & Answers
Use ImgBurn. When burning data/music to disc. Choose 4x or lowers write speed. Faster write speeds have more chance of error. If you want the most accurate burn, I would suggest 2x. It may take a while but a chance of error is very low
HP Compaq... | Answered on Jan 28, 2019
repeat process posted by tim noack but on device manager,right-click on mic.
click properties.
on driver,click rollback.
if no joy,unplug mic,
uninstall.
restart laptop.
when started,plug mic in & re-install
HP Compaq... | Answered on May 06, 2014
right-click on your desktop.
from the list,click on personalisation.
click display.
choose monitor.
choose screen resolution.
click apply.
if ok click yes.
if not,repeat steps with other resolution.
Go here
All you have to do is enter the Os Version and then click next and there is all of the drivers for your computer!
HP Compaq... | Answered on Sep 11, 2012
You could have a bad batch of disks or you could try a different burning app like Imgburn, which is FREE. You can get it here...:
http://www.imgburn.com/
HP Compaq... | Answered on Jul 01, 2012
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
HP Compaq... | Answered on Oct 10, 2010
check device manager may be the device is disabled otherwise you are trying a wrong driver.
or
for some audio drivers u have to run universal audio architecture from microsoft. i think this is your problem. download microsoft universal audio architecture and install that after that install audio driver.
Before that check device manager for device enabled or disabled?
HP Compaq... | Answered on Jun 18, 2010
here is the weblink to install the sound driver for your notebook :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-64867-1&lc=en&dlc=en&cc=us&product=3629516&sw_lang=&os=2093
install the driver and restart the notebook. Then check for the issue.
HP Compaq... | Answered on Jun 11, 2010
there is nothing to worry about. You can download all your drivers from the HP link below;
http://welcome.hp.com/country/us/en/support_task.html?pageDisplay=drivers
when the link opens, enter your laptop model and press enter. You will also be asked to select your operating system (win xp or vista), then you cam proceed for the download.
You will find all the drivers for your PC, that's why I said there is nothing to worry about.
Take care.
HP Compaq... | Answered on May 24, 2010
Click Here to download the latest version of drivers for your HP Compaq Presario C700T.
Please let me know if you have any further questions or concerns.
Thanks.
HP Compaq... | Answered on May 08, 2010
obtain the drivers from the manufacturers website
HP Compaq... | Answered on Apr 01, 2010
the formating disk may be don't have correct data or else some hardware failure may have occured..........
HP Compaq... | Answered on Mar 26, 2010
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the
XP Windows version of the drivers you require and install them.
Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
I had the same problem
eventualy the end fell off
i had a look at it and it turns out that the connector, after general use, snaps inside because the connection between the main wire and the connector got bent when i charged my laptop
i am now on my third charger and even that is dodgy
HP Compaq... | Answered on Mar 08, 2010
this should be the driver you need.
HP Compaq... | Answered on Feb 26, 2010
Hello Vikasglobalr, hi! you need to install the sound driver for your c700 notebook. you need the CD driver that comes with your laptop.
HP Compaq... | Answered on Feb 23, 2010
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jakauiay39
HP Compaq... | Answered on Jan 03, 2010
HP Compaq Presario C700T Notebook Logo
52 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
disc wasnt burned successfully make sure
  • Computers & Internet
