Delta & Single Handle Shower Faucet  Logo
Brian Smith Posted on Apr 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The handle leaks and I removed the screw in the handle and it won't even budge when I try to take it off any suggestions?
bzet1820
Level 3:
  • Master 700 Answers
  • Posted on Apr 06, 2015
bzet1820
Master
Level 3:
Answers
700
Questions
Helped
211709
Points
2147
Calcium build up "froze" the handle, would suggest immerse it in vinegar, or clr (do not know your local equvalent), or similar weak acid and leave for few minutes, run water through and then tap gently to try to dislodge it, repeat if necessary, and second time leave bit longer in acid.
i do not understand "handle leaks" - usually taps (faucets) do that... handle leak only if split or otherways physically damaged - it usually requires replacement, as handles are (including hose) extremely cheap and start with about $10.00 at any hardware store - i would not bother with repair - just replace.
another what can be wrong is seal gasket in handle mount. this cost few cents and is worth repairing... :-)
hope this will help you - do not forget to vote...
The cold water handle of my two handles Starck faucet leaks when turning either the cold or the hot water. How can I remove the handle? There are no visible screws nor plugs. Thank you.
I assume you are referring to the Hangrohe. https://images.homedepot-static.com/catalog/pdfimages/a7/a79e5618-65fc-4e21-9a59-dd8bcc4773aa.pdf
It appears there are detents that hold the handle so push ON and pull OFF. Firm grip and pull should remove the handle. Although, if yours has leaked for weeks/months, corrosion/deposits under handle may make it difficult. If coldle hand doesn't budge, try removing the hot as it has not been leaking and may pop off with less effort. Then go after the other. Note; you may as well replace both cartridges.
Apr 18, 2019 • Plumbing
Blanco kitchen tap handles cannot be removed.
you need to unscrew the lever handle and in the bottom of the threaded recess you will see a 4mm allen head screw. Loosen this a couple of turns with a 4mm allen key and the complete handle will slide off to give you access to the cartridge
Read more: https://www.diynot.com/diy/threads/removing-blanco-tap-handles.378938/#ixzz70WYg3ojT
Jan 31, 2019 • Plumbing
I have a Moen 7730 single handle kitchen faucet. There is a slow drip from the end of the spout. I was going to replace the cartridge but I have stripped the hex screw under the handle (it was corro
Get a screw extractor kit, if your lucky you can get the screw extractor to wedge into whats left of the hex and force it out, but even then it might not come out, i would recommend getting some penetrating oil, like PB Blaster, regular old WD-40 is ok for lubricating but its not a penetrating fluid, soak it in the morning and go about your day and then dry it in the evening, if it still won't budge you might have to remove the whole faucet from the sink and take it to an area you can clearly work on it and drill out the set screw with a drill bit that fits in the hex to make the hole in the center of it deeper to give the screw extractor a better grip. I've been there done that a few times, it takes time and patience, and in the end they cant all be saved.
Jan 02, 2018 • Plumbing
How to remove handle on 34 series brook wood
It is unclear to me exactly what you are trying to remove....given
that, I suggest a spray lubricant and let sit to work in....if the screw
head is not stripped keep it so...a long handled screwdriver will
work better...use more lubricant if you have to- do not force.
Regards,
Dennis
Aug 22, 2014 • Plumbing
Screw too tight on spider
Spray it with WD40 , take a minute or two and try removing it .
Remove handles from price pfister treviso double handle faucet
replace rubber seal in tap need to unscrew the nut to get at it
Nov 27, 2011 • Plumbing
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
1helpful
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
