20 Most Recent Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Questions & Answers
3answers
Air compressor needs a new hose from engine to tank
Go to the manufacturer's website and order it
4/17/2020 10:59:57 PM • Campbell... • Answered on Apr 17, 2020
6answers
Husky wl651004aj 17 gallon my compressor
There may be a reset button on or near the motor. If you see one push it. Also are you sure you have power at the outlet. In most garages built within the last 10 years all the outlets are protected by a GFCI outlet. Power runs through this outlet to all the others. Make sure it has not tripped. If you have voltage at the outlet where the compressor is plugged in and there is no reset button it has an internal breaker that should reset itself after the motor cools off. If it does not then the breaker may be bad or the on/off switch is bad. To make sure nothing is wrong with the connection at the outlet, plug it into another outlet without an extension cord just to make sure.
4/7/2019 9:39:22 PM • Campbell... • Answered on Apr 07, 2019
2answers
Need to replace bearing on the pump/motor unit.
YOU CANT THATS PRESSED ON TO THE ROD
3/7/2016 12:22:20 AM • Campbell... • Answered on Mar 07, 2016
2answers
I have Model WL660900AJ 26
gary, i have the same tank same problem.. i havent replaced any parts yet... have you found a resolution to this issue?
7/23/2015 1:13:18 PM • Campbell... • Answered on Jul 23, 2015
0answers
0answers
2answers
Husky 26 gallon air compressor runs but will not
replace the valve plate
10/6/2013 2:34:04 AM • Campbell... • Answered on Oct 06, 2013
Compression ring from sears part number DAC-308 would it fit husky wl651001aj air compressor
only if piston and cylinder size are identical
4/14/2013 12:57:16 PM • Campbell... • Answered on Apr 14, 2013
2answers
I have a Husky air compressor model WL651004AJ.
It sounds like you need to replace the run capacitor , if yours is weak or defective the motor will overheat. Check "Drillspot" for a replacement. Another major cause of overheating is due to a dirty air filter , you should check it first.
Don F
8/21/2012 7:36:48 PM • Campbell... • Answered on Aug 21, 2012
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
98 questions posted
Top Campbell Hausfeld Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Campbell Hausfeld Air Tools & Compressors
Most Popular Question
husky manual tf291201aj
  • Air Tools & Compressors
